George, I have not made any changes to the published app yet. So, whatever you see is something that Apple is doing.
I will investigate.
And again… apologies for the delay in the update.
–Sam
I will investigate.
–Sam
I don’t know if there is an issue. For a while the APP was not available via the IPHONE APP app. Now it is again… Not sure why but wanted to check to see if the latest btstwx was something new or the old app. Sounds like it is just the old app… and you have something coming out new at some point in the future (god willing :-))
Yes… I am planning a major update to the app very soon.
I have been super busy with other personal things, as well as a job change… all have slowed my projected development plans.
–Sam
I tried this windows version btstWx_x64.zip with my Dell laptop runing windows 10 but does not go past my entering my station ID (SWS43855)… FREEZES.
And google play does not let me use your androide app on my Samsung SM-T310 runing android 4.4.2 which would have been à great way to reuse my pad
I do not want to use bluestack etc. nor paste my Samsung A71 cell to à wall.
Thanks, I will look into the Win10 version.
I am not sure I can support anything older than Android 5, but I will check on that as well.
–Sam
@St-Tremblay
I just downloaded the Windows version, and tried my demo station (SWS1158) and your station (SWS43855, Mont-Saint-Hilaire) and they both worked without issue.
However, I do get a “station offline” message from your station at times. Is it running in power-save mode?
–Sam
Bonjour à tous,
Je n’arrive pas à trouver la version Windows ni celle d’IOS ? Merci pour votre aide
Where is the windows version download?
Génial, merci. et pour IOS et Android pas encore développée ? (weatherbox?)
Je travaille sur une mise à jour de l’application existante (btstWx), ainsi qu’une mise à niveau complète vers WeatherBox.
Je prévois de publier la mise à jour très bientôt. La version WeatherBox sera plus tardive.
I am working on an update for the existing app (btstWx), as well as a full upgrade to WeatherBox.
I plan on releasing the update very soon. The WeatherBox release will be later.
Merci pour votre travail
bon courage !
On garde un œil sur vos mises à jour
No, not running in a power save mode.
I retried my 3.8.7. Version of windows btstWx and still freezes at the “Verifying Access…” page.
N.B. The only station that seems to work is the FWYC1951… but data does not change.
P.S. Both the MEmu & Bluestack way work but cpu usage is terrible. Raison why I want a direct windows 10 version.
-------- Message d’origine --------
Thanks.
I will troubleshoot this more today.
I’ve only been using the app on my fire tablet 7 for about 24 hours and I love the display and the information that is provided in portrait mode. All of a sudden I noticed the stats weren’t updating and there was a “Loading” wind flag icon on the screen. I tried closing the app and re-opening, restarting the tablet, and uninstalling/reinstalling the app and all the same stuff. After re-installing, I got to the “Verifying access” message and it just sticks at “Loading”. See screenshot for reference. Any idea what could be going on? I would love to continue using this app as my permanent display and if I can get it working, may opt to buy the pro version to support you. Thanks!
Thanks. Others are having this issue as well. Checking on it now.
–Sam
I have also had this issue a couple times. Not sure if this is a fix. Each time I closed the app, started up the WeatherFlow app, after it connects I close it down. Than I restart btstWX and it starts working.
Today, I had to install another app on my tablet so I could remote control it from my computer so I had to close the btstWx app. Upon trying to re-open it, it get’s stuck in the “Locating Position” and “loading” screen again and never actually loads. Unfortunately I think your method may have been convenient timing or it “just works” for you as it did not work for me. Has this worked for you pretty consistently? The app had been working fine for a couple days prior to me having to close the app.
I had to restart my tablet and the btstWX is no longer working.
Bonjour, du nouveau pour cette application ?
Merci
