I have two tempest weather stations and would like to be able to view either station on the PiConsole. I noticed that in the menu of the wfpiconsole that you could select weather stations, but how would that be setup?
You can use the menu to switch between different devices/stations. You can’t display data from two devices at the same time
But how is that setup in the pi console since you only sign up one weather station?
During the initial setup you enter your Tempest Personal Access Token. That then gives the PiConsole access to all the stations/devices registered to your account. You also have to manually enter details of the station/Tempest you initially want to display, but these can then be changed interactively though the PiConsole menu
