Hi all, my tempest had been working well untill I rebooted my router. Here’s what happens:
When trying to reconnect the wifi I first power cycle the hub.
The led turns red
I start the app
The led turns blue
Then settings, stations,choose my station, wifi setup, next, message “Scanning”, then after about 3 seconds the led turns red, then I get a message No wifi found.
Sometimes I get an error code 1006.
Here’s what I have done:
- Rebooted the hub.
- Reset the hub
- Confirmed my tablet was connected to a 2.4 ghz ssid
After resetting the hub it found my Tempest device by itself so I did not have to resync.
Rarely I have been able to reconnect to wifi, the led turns green, but the connection lasts, at best, a few hours. Mostly I have the problems mentioned above.
The hub and router are in the same room, about 8 feet away from each other. No other devices are losing connection on my network.
Any help would be very much appreciated.
