Frequent Disconnects
My unit has been deployed since June with few disconnects. This week it’s had several each day. Any thoughts as to cause? WeatherFlow: Device offline - ST-00006551
What is your Station ID? You can quickly get a link to it by using the share icon and posting it and/or putting it in your profile here on the forum so we can take a look and help.
It looks like the RSSI is way out of range.
It needs to be better than -70db but I have a station running around -75db and doing OK.
For testing I moved the hub outside, clear line of sight, less than 60 feet away from the station. Best signal I can get is -69. Shouldn’t that be better?
That should be fine. For the station I put at our church I found that rotating the hub so the right side (left side if facing the LED) was toward the Tempest I got the best signal strength. That one is at -72db and doing fine.
Thanks, I’ll watch it and see how it does in the new location.
