Hub ready for IPv6?
As eric already mentioned in march
Hence, I couldn’t see any response to that point, and the topic will raise in actuallity (see MAC adress for Hub), it would be nice if @WFmarketing could provide some info.
Is the Hub allready IPv6-ready ?
Is the topic on mind / scheduled ?
Will the Hub be able to handle IPv6, maybe after a later firmware update?
Yes, the hub is capable and the framework for IPv6 is there. It will just require a bit of code in the firmware to enable it followed by a lot of testing.
Thanks David.
I just saw the info in the
Release notes for firmware version 91
Good luck at testing…
By the way… once I’ll receive my sets, I am would be happy to assist you with testing…
