If battery life wasn’t a concern, could tempest measure wind more often than every 3 seconds?
Say if Battery life wasn’t a concern, for instance the Tempests that are plugged in all the time via the booster, would it be capable of measuring the wind all the time? It seems like sometimes my tempest misses wind gusts that only last for 1-2 seconds.
It is my understanding that the 3-second sample rate was mostly due to energy consumption. If true, it would be able to sample more often. It would be interesting to see the energy consumption if it were to sample on 1-second intervals, and to compare the wind gust and average wind speeds.
Remember there’s a difference in how often the sensor measures’ things versus how often it ‘reports’ the aggregate measurement over some reporting interval. The actual sensors might be running on a quick loop and just not reporting it as often. Really depends on where the math is, is it in the sensor or in the hub.
