Issues with Sky mount (solved)
I have my Sky unit temporarily mounted on a 60" galvanized 1" pole. Tonight I attempted to add another 60" pole. I pulled the 1st pole out of the ground and tilted it over to remove the Sky when the sky mount came apart. It looks like it should have 4 little screws in there maybe. Otherwise, its o ly held together with friction. With the installed gasket the friction pieces don’t make contact with each other…I discovered that when I tried to crazy glue them together. Currently at a loss as to how to get it to hold together, any ideas are welcome.
Dave20180530_180341
Can you pls. post a couple more pics (side angle, etc) so we have a better idea what’s going on? Thanks!
Dave, there should be four little screws and a vinyl sticker (with the “WeatherFlow” logo and compliance icons) covering that. Looks like your pole mount is missing the four little screws! Please open a ticket with support by filling out the form http://got.wf/contact or send an email to support@weatherflow.com and we’ll get a replacement out to you ASAP.
20180530_180521
Looks like you didn’t get screwed.
:smiley::smiley::smiley:
