update is pushed to your hub, but it can take some time before all stations are done. It is trickle wise as not to overload systems I think and last time it took several days.
But you can always do as Gary said if tomorrow it hasn’t updated.
To keep it simple, the apps display rain totals for the “local day” (“yesterday” and “today” in the main UI and for any other day on the graphs by zooming all the way out). If you’d like to see it differently, please add a request to the Feature Requests category
Many thanks! My hub is now at version 98. As far as the notes mentioned for v98, " * added additional methods to upgrade firmware and set time" does “additional methods” mean that this will come with an update iOS app?
It appears V98 has knocked my rain sensitivity out. Despite moderate to heavy rain over the last day or so nothing has been recorded. My Weather Stn. is 2120.
Essentially, every SKY unit is still using the same calibration curve, despite the fact that the exact method used to mount the SKY has a large impact on its sensitivity. This is making some too sensitive, some under sensitive and some just right. This will be fixed when WF roll out the continuous learning scheme for rainfall, and the calibration becomes specific to each station.
It looks my Sky is back to recording rain. Today it’s been quite wet with approximately 8mm of rain. This is within + or - 1mm compared with neighbouring weather stations of various makes in nearby streets so the accuracy seems to be good as well.
