I am a new user…had my sensor installed above roof…some 6 ft above line. No data.
Found out that you must pair your sensor with hub via your cell before mounting.
System is working fine…it is awesome.
Patrick
Patrick
Yes, it is definitely important to make sure everything is setup and working before mounting the Tempest. If you didn’t get the flyer enclosed in the Tempest box, here it is. (Note step 2).
Also note the full setup instructions at got.wf/tempest-start and note the first part of step 3 or the note right under Initial Setup Tips, “Configure your station in the mobile app before installing the Tempest device outdoors.” This is what @snowpagano is referring to.
