I just installed my units. Look great. On the app I am not seeing the rain, solar or wind cards. I only see temps, pressure, lightning, forecast, and battery voltage. DO I need to manually select to add these somehow. I did not see any instructions on this.
Except the battery card and forecast, the cards should show up when a module is active. Are you sure all you modules are linked to the hub and reporting ? (push the little green online button to flip an d see details) …
also delete cache of your browser, sometime …
What is your Station ID or the Serisl Number of your Hub?
It was a setup problem. with the Sky. I reset it and attempted setup again. It works fine now
welcome to the club
