My sky unit broke down. Before throwing it in the recycling bin, I want to open it up. Four screws at the bottom was step 1, desoldering the power wires step 2, I didn’t want to open up the antenna in order to desolder it, so I cut the wire. Now I’m left with the top part.
There was a tiny bit of green stuff (glue?) between the brass part and the plastic which I scratched away. Big question is how to proceed to open the top part
I don’t want to just smash it yet, in case something repairable is wrong.
any ideas?
I’m kind of expecting the white part immediately surrounding the the transducers to just slide over the metal part, but it seems stuck.
is there some glue only next to the transducers, or all around the edge?
all of my six
had some thin silicon seal more like a white elastic band. dont recall anything around then wind sensors it was a couple of years ago .but its not the wind sensors keeping the lid on . your see when you pop it off…
easier said than done. I went around with a knife a dozen times, still no movement. I’ve put the white part around the metal in a vise and pulled the cap. No movement. I even put the metal part in the vise but I assume that is attached to the plastic part around the brightness sensor, so I didn’t expect that to move. It didn’t anyway.
ok so a thin screwdriver prize it in between to open a small gap then move it up , unless they superglued later revisions , i recall all came off without any heavy force , tempted to dig one out of the cupboard and video it for you … just keep trying …
got it. scewdriver and more brute force did the trick. There are four tiny notches next to each transducer. Some weather influence is visible around there. Inside, where the electronics are, everything still looks unweathered.
cool now you can salvage the piezoelectric and use it for an acoustic guitar pickup as i did
have fun…
wow, turning a weather station into a guitar, that’s cool. Actually the only thing working in this unit was the battery sensor and the piezoelectric.
I am late to reply now that you managed it, but this post shows my method and the tabs:
https://community.tempest.earth/t/failing-sky-investigation-discussion/7034/4
cheers Ian
that would have been helpful.
In my case the nut showed some corrosion. Using different metals for nut and bold isn’t generally a good idea, as this accelerates the corrosion. I have no idea why the wind and solar sensors failed, but battery and rain were working fine.
I can’t remember that being a problem at all. I guess a bit more force? But I really can’t remember.
Ok, I’ll more force ago! I was just checking there were no tabs or anything
there are 4 tabs when opening the dome on top. Use a sharp knife or something like that. Be careful as there is also some silicon ring, so don’t go to deep.
Hi @peter ,
If you look carefully at my picture in this post I think I can see the marks where I squeezed a blade or screwdriver into the top seam.
I guess I prized it apart in stages perhaps beginning with a knife then using a screw driver moving gradually around the seam.
cheers Ian
Not me, I just examined where the components were. It helped me to understand the antenna location which is valuable because I use them many km away where the direction I place them can make a difference.
And helped me to know what is inside and how it works.
