SKYpole (left) - SKYFT1 (right - field test, super hydrophilic coating). Two different poles - left is a lighter aluminum pole with vibration dampening : right mounted to a rigid, galvanized steel chain link top rail. SKYFT1 is about 2 feet higher.
Just finished installing it on the mast with the Davis gear. Should be good for comparing readings.
Hi @seaman55,
Is the pole designed to undo the one bolt on the left and rotate it to the right?
I like several aspects, also how you combined the two poles with those clamps.
FWIW, my VP2 and Sky share the same mast:
Do they argue with each other? :wink:
Hello @iladyman ,
One of the reason’s I set it up this way is that it is very adjustable, I’m pretty sure the answer to your question is yes, but to be sure I am truly answering your question accurately, I need to know exactly which bolt you are referring to. There are quite a few clamps and bolts.
100m from shore or any other obstruction. Love the Solar option!
How did you get that installed up there ? The flag isn’t causing to much false rain under heavy wind ?
Windsurf mast on a screw mount. I don’t care about rain readings and value the flag for visuals on wind behavior.
I wanted to have mine with a little more space between, with less potential for interference, and to get the air sensors at the same height, for a real close comparison.
Probably overkill, but that’s just how I am.
If you look at the second picture link, they are at the same exact height…
Hi @seaman55,
I refer to the left leg of the tripod where it attaches to the bracket on the side of the roof with only one attachment to the roof. I guess either the horizontal bolt between the bracket and the leg, but the bolt into the roof if for any reason was easier to undo then that one. And I am guessing the 2 brackets on the right of the roof can remain bolted, but perhaps loosened to allow easy rotation.
I have a pole system which rotates in a different pattern to this.
But I am currently considering another pole mount on my roof to secure some cameras and your design contributes to my thoughts thank you.
Nice place :blush:
What for is the antenna (?) at the left side ?
Home made tower side mount for my Sky using PVC located up 25 feet on a ham radio tower.
If only I could have something like that in my back yard… :frowning:
if only I had a back yard … :wink:
The antennas are a Ubiquity mesh WiFi access point. It does a great job with coverage mounted up there.
I like the Unifi mesh AP on the same Sky mount!
