We’ll, that’s not the case but OK. Maybe someone else can help, I appreciate you chiming in, but maybe this one you can skip?
Setup:
Raspberry Pi 4 Model B Rev 1.4
Kernel: 6.1.13-v8+ #1632 SMP PREEMPT Thu Feb 23 12:26:19 GMT 2023 aarch64 GNU/Linux
Tempest Version: v22.12.3
Debian GNU/Linux 11 (bullseye)
DE: Light Display Manager 1.26.0
Touchscreen:
Raspberry Pi 7" Touch Screen Display
So…
Does anyone else have screen saving working, because about a month ago, it stopped working on the PIConsole. My PIConsole touchscreen now ignores any sleep or screen saver settings.
What @vinceskahan is trying to say is that the issues you are facing are very unlikely to be caused by the PiConsole, and rather are likely related to some change/update that has been made to your Raspberry Pi itself (probably through an update). I have no knowledge of xserver commands so you might want to ask elsewhere for help
We love you too. Thank you so much. It’s unfortunate you are so sensitive.
I was suggesting you should ask in the appropriate site for such questions. PiConsole doesn’t even ‘use’ Xwindows so what you described ‘had’ to be unrelated and an os issue that you should ask in an os forum (not here).
The WF forums can’t be expected to duplicate 20+ years of the entire Internet. Google it for heaven’s sake.
Consider taking your original question and rewording it just slightly…
I have two cars. Both of them no longer have bluetooth working.
Previously, this worked by pressing the button on the display.
Not sure what changed.
Car info: Toyota Corolla (Both the same)
Model year 2020
Is there anything I can provide or try to remedy this?
Now in that case would you really expect somebody here to say anything other than ‘you might want to ask on a Toyota users site’ ???
My Piconsole’s screen no longer goes to sleep after 5 minutes either after running pi updates as well as the latest piconsole update this morning. I am unconcerned.
Jim
apt install xserver-xorg-core=2:1.20.11-1+deb11u5
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
xserver-xorg-core is already the newest version (2:1.20.11-1+deb11u5).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Avoid upgrades for the time being (already done for me)
Thanks so much for this … after the last update - which forced me to rebuild from scratch both of my Rpi wfpiconsole systems, I lost the ability to blank the screen at night.
I had a cron task switch between day & night - allowing me to make dark the screen while no one was awake to see it.
Followed your instructions, and ALL is back to the way it was.
Edit: It would be a nice feature for Peter to add within the ‘Settings’ to have screen active/blanking schedule.
I hope other’s in this thread take this interaction as a lesson in the future. It’s OK to help each outside of the boundaries of PiConsole since everything interacts together in some way.
