Rain water leaking into solar panel batterycompartement
Today i did some cleaning maintenance on the Sky.
Then I noticed something on my solar panel.
I don’t know how watertight the battery compartment is of solar panel, but there was water leaking out on the side.
You can see there is a little space between the plastic and the rubber sealing.
That was exactly the place where water was leaking out of it.
Also there was a lot of rainwater comming out between the Sky unit and solar panel itself.
We had quite a summerstorm yesterday with some showers. So the wind was blowing the water on it more than normal.
Should I contact WF for it?
Everything still works fine.
Peter
leaking out of it would be ok, but how did it get in?
(just joking, I would definitely contact support)
That’s definitly a case to reach out @anon84912554.
Best way is to open a ticket.
Thnx I already contacted WF support. Awaiting their reaction. :blush:
