Show WF Map in "station" and "share" URL
When you view the URL that is designed to be shared for any given station, you see a link to the official Weather Flow map at the bottom:
Map
However, when you view the “station” URL (i.e. the one that allows you to modify your own station configuration) there is no map visible. Can the official Weather Flow map be added to this station view as well?
NoMap
Good idea! We’ll add this soon.
but why?? you should know where your own station is.
As a simple link to access the map with all the other stations. And yes, we are exploring various ways to expose links to the map in the mobile apps and web apps.
Because sometimes I want to compare my observations with stations around me via the map, and currently there is no easy way to do that if you are on your own station’s page.
@dsj and @WFmarketing thanks for looking into this! :smiley:
that’s a usefull adition
even better would be if both url’s were just the same. there difference could be made at the server
Ha! That’s exactly the solution we’re planning. Great minds think alike? :wink:
