Ok…so for all of us in this particular situation, it’s not the “height” of the sky, it’s the height away from “objects”. Essentially we can install the sky anywhere as long as we have “clear air”. Raising it 20’ is doable but can mountain
Regarding the need to mount your SKY way up on the roof… actually, it is not imperative that users mount their SKY up in some scary or HOA non-compliant location. Sure, if you can access a location free of physical obstructions that impact the wind fetch you will get cleaner wind readings. And yes, there are meteorological standards for professional installation sites for government networks. But, let’s be real here, this is your home, your data, your choice to mount your SKY wherever you feel comfortable.
