Station Offline - multiple times over the last 3 days
So I’ve now received 6 notifications over the last 3 days that my hub and station are going offline and then reconnecting. Things I know to be true about the current setup and situation of my Tempest:
  1. The hub has remained fully powered and plugged in with no interruption of power
  2. The wifi within the house has had no interruptions (I actively monitor it through my UniFi application)
  3. The Hub is on Firmware v143 and the station is on Firmware v129
  4. Both devices show RSSI -60
As this is not a power or wifi issue what else should I be looking at? The full system was setup on 28 June and powered on. I did have to move the hub once so that it was in a better position to receive a more constant and direct wifi signal from the local AP its now connected to. Up until the 28th there were ZERO issues with connection based on the logs.
I originally though that the system was trying to perform the firmware updates but now I see that it’s still on the original firmware it was shipped with.
Looking for suggestions from the Pros that have been using this system for more than a month or two or some input from the @WeatherFlow folks directly.
Cheers-
Got the same problem… i have fw 156 on the station and fw 169 on my hub. Station began going offline and coming back online with very weird metrics. Then offline and online again and then again… eventually it’s now offline for the last 5 hours.
your station was ok but started to discharge rapidly after yesterday’s rain shower.
Now it is offline since drained battery
Can you have a look and eventually shake it and listen if you hear some water in it ???
Nothing more I can do here, please open a support ticket. They will help you out.
