Switch Tempest to an existing HUB
I have 2 Tempests and HUBs and one of the hubs has disconnected from WiFi and I cannot get it to reconnect. It either does not see any WiFi SSIDs or if it does, it will not connect and it returns a 326 error in the app. I previously had intermittent WiFi issues with the HUBs and switched both HUBs to a 2.4G only SSID over a year ago based on some reading here on the forum about WiFi HUB connectivity issues. The WiFi RSSI levels for the HUBS is typically -45dBm or better.
The other HUB is physically adjacent to this one has no connectivity issues and has another Tempest and AIR connected to it. Is it possible to switch the Tempest to the good HUB without losing historical data or messing up my UDP data?
You should contact support to see if they can do what you want. They are the only ones who can transfer data over when switching to a new hub.
I hope they will respond.
