Temperature forecast
Well this is a strange one… it shows an expected max of 23 degrees, however the hourly expected value has a max of 21. I guess it might be true, using rounding and the actual daily max temp is reached just in between the hourly measurements. But it is a bit surprising anyway.
@sunny. Maybe your unit is hoping for warmer weather?
Old topic that apparently won’t give up. Daily forecast says high of 62 but hourly shows 42. Weather Channel says 48 for high. I’m quite certain that we will not hit 62 today. How did we get here?
Yeah, I’ve noticed some really wonky things on my forecasted temperatures. Does anyone know where this info is being pulled from? Today was showing the high as 38, and we haven’t even hit 25 yet. I’m 99.9% certain we’re not going to jump 23 degrees in the 3 hours left of daylight. My forecasts are usually pretty inaccurate. I’m forced to rely on AccuWeather still for forecasts.
Only been online a couple of days so far but here in SE PA it is close to accurate as I can tell. Maybe in a couple of weeks after being online for awhile things will change (hoping not) but only time will tell.
