Tempest Hub Redesign --- New Look
I think that the edit using strikethrough text (leaving the text in place) was proper to correct the misinformation provided by the support department.
Also, I don’t know if it is available to all user permissions levels, but the Discord forum software has a complete edit history available on all posts via the orange pencil with a badge count on top of each edited post…
Nobody checks edit history. I’d suggest that if he wants to edit it, he should clearly mark that ‘he’ edited the changes, not the original poster. That would be an ok middle ground for me.
<---- Frequently checks edit history on all Discord forums that I’m a member of.
Also worth adding a footnote that both the new wifi and this ethernet Hub have the power input and LED status indicators on the opposite side from the antenna. Since they supposedly come with wall-mount brackets from what I’ve read, the plug locations aren’t a deal-breaker for me.
(Note to @eric to feel free to strikethrough the brackets thing above if I’m mistaken…)
indeed, don’t edit somebody else’s posts. You can ask them to correct the post.
I just received the “new” updated purple hub. I need to stop using the “old” style hub and connect the new. I can’t seem to find any info on if I will lose any data history or such. Is it the same procedure as if I am starting from scratch with a TWS?
Also, mine did not come with a bracket I have seem mentioned.
  1. Contact Support. They can “stitch” the data in from the old “Classic Wi-Fi” Hub to the new “purple” one. In that process. . .you might lose about 12 hours-worth of historical data. . .but the remainder going back in history would still be there.
  2. For the new “purple” Hub (TE-HUB). . .the mounting bracket snaps onto the back as shown in the highlighted portion of the image below. If your “purple” Hub did not have the bracket snapped onto the back. . .again. . .contact Support so that they can send a bracket to you.
Just reviewed your top post from above. You’d mentioned your Hub has an Ethernet port on it as well. To my knowledge. . .the “purple” Wi-Fi Hub does not have the Ethernet port on it. Only the more expensive “industrial strength” Hub does. . .but it is gray in color…not purple. The “gray” Hub should also have a bracket that snaps onto the back of the hub. . .but the bracket is not shown in the image below.
I had accidently ordered the wrong one.
Thanks for the heads up with the data. I will call them tomorrow to preserve my data.
Really wish this was shipped with the Tempest weather station instead of the WiFi only model or at least provide another package option with this hub at an increase price to offset the cost difference. Would much rather have an Ethernet connection instead of WiFi. Can’t justify $150 for an Ethernet adapter.
Unfortunately the provided link TempestOne WiFi Hub device leads to a 404-error.
Whats the steps to get the Hub with the Ethernet-option? The price is quite high however I would consider it as I prefer wired connections.
The link works for me…
thanks for your reply, thats very strange, I tried to access it from Firefox and Safari (latest version as of November 9) and get the below error.
I also couldn’t find it via the all products
I get the same 404 error. Are you located in the US? I wonder if there is a geographical restriction (I am in the UK)
It is labeled “NA” in the title, which I assume means North America…
good point, yeah I am from Switzerland.
may somebody from the Tempest-team can provide information if the Hub is only for NA and if so, will there also be a version for Europe coming?
quick update on this topic. I got the below answer from the support, fingers crossed :slight_smile:
Unfortunately, at the moment it is only available in North America, but we do plan on releasing it internationally in the future.
. . .And Now. . .the “purple” TE-HUB that has been around since about June of last year (2024)
has now been replaced with even a Newer HUB . .
In addition. . .the back side of the Tempest sensor device. . .Finally has the t° logo etched into it instead of the old WeatherFlow logo that has been around since ~ 2016. . .when the system was first developed.
thanks, very interesting. I guess that due to the naming that includes Wifi its probably just a wireless-Hub with no ethernet-port.
Unfortunately its still not possible (at least for EU-based users) to purchase the Ethernet-version of the hub with the grey color scheme.
I wonder what the differences are between them if there are any besides thefootprint.
Good to see the cord and status lights aren’t on the same side now.
I am glad to see that it has an antenna which can be rotated up into the vertical position. Lots different than the “Classic Wi-Fi Hub(s)” that I am still using. The antenna on Classic Hub is internal (encased in the plastic housing) and attached to the main PCB (PrintedCircuitBoard) and located on the Left side of the classic hub (as you look at the USB plug-in AND the Green LED facing you.) The antenna on the Classic Hub could not be seen since it was internal. See Historical Images below. For the second image. . .the antenna is the black item on the left (attached to back side of PCB.)
