I had - but noting the WD update, i added it back in to see if it would work - only removed to see if the other unit was the problem.
Andy
Andy
and you do have the name for that sensor (name only) set in the WD setup?
also if you click on get names, does that sensor name (and ID) show OK in the list in the setup?
(and in the top right hand corner of the cronweatherflow station)
I could add some more debug code…
but I will try some more testing here
Yep get names displays them in WD and Cronweatherflow - also the sensor is as named in the list:
Andy
try another .zip update of WD (which has a new cronweatherflow.exe (vers 3.7)
I might have it working now (hard to test without a second AIR)
