Choose which Air Reports Data
I now have two Air devices one with a bad barometric sensor is there a way to choose which one reports to WU for the current conditions? I moved the one with the bad sensor to an indoor location and placed the new one outside where the old one was.
Did you mark the broken Air as an indoor unit in the WF app’s settings?
WF Support may need to get involved if that doesn’t work…
Yes I have marked the old Air as a indoor unit.
Remove the bad Air then add it again. It’s the unit with the lowest device ID that gets used.
Excellent thanks for the help.
