Using Weatherflow API to feed Easyweather
I have started using Easyweather on my server with data from Weatherflow. it’s here http://www.twinfirs.co.uk
My question is the data feed, it appears that Weatherflow restricts the data feed to every 5 minutes, is this correct?
Unlikely. WeatherFlow data is available every minute and the API updates in real time. I suspect it is the software you are using that is only requesting data every 5 minutes
Thanks Peter this is what I thought.
If this is anything like weewx, then there is probably a setting in the config to increase the polling rate.
I have my site at http://farnhamweather.com updating every 150 seconds, however its offline at the moment due to no power/sunshine! Before it went offline I did notice that the site refresh dropped back to the Tempest refresh of 5 minutes when it went into power save mode - how’s your battery looking?
Cheers
Simon
Okay I have had a reply from the site and for Weatherflow that have a cron job getting data every 300 seconds. I would like to reduce this update time but what can Weatheflow handle what is the minimum refresh time
WeatherFlow have never published any official usage limits, but I imagine the minimum refresh time would be every 60 seconds. Any faster than this won’t gain anything as no new data will be available.
@simon2, in Weewx there is a difference between the archive interval and the polling rate. Assuming you are using the UDP driver, Weewx will be getting a new observation every three seconds for wind and every minute for everything else. The 150 seconds refers to the period of time over which these observations are aggregated to generate a single record.
