WeatherFlow ROKU Channel v5!
I know this will get merged with previous posts; still not sure how to do that :slight_smile:
Weather Station Data v5 for WeatherFlow released today and is available in the ROKU Channel Library.
This release will default to a “dashboard” view of WeatherFlow data.
The “tabular” view is still available through the configuration.
This release includes:
  • Humidex for our friends in the Great White North
  • 5-Day forecast
  • Dashboard view of data
To install on your ROKU:
Main Menu → Search → “weatherflow”, the “channel poster” will look like below.
Channel-Poster-V5-540x405
If you already have the channel it will eventually update on its own, OR you can request the update by:
Highlighting the channel → Press * → Check for Updates
I invite feedback and suggestions!!
So I found your channel (version 4) but when I enter my station number 00029945 it comes up with a station in Arizona.
Thank you so much for the interest!
PLEASE double-check your station number, I checked it and got the results below.
Look on your phone app and check the number.
Please respond and let me know how you do !!
Thank you for getting back to me.
Per my Tempest app my device is ST-00029945 and the name is yew st weather.
As @steve.palmieri said, the station ID is the number at the end of the URL that you can get from the Public Data screen. You can also get it from the Status screen.the ST-00029945 is the device ID for the Tempest, not the station ID (I have not checked, but, you also have at least one more device ID … for the hub ( it looks like HB-nnnnnnn ). The station ID is distinct from the device IDs.
I have it up now missed the need to use the public data. Thanks for your help.
------------------>> Ping to the group <<-----------------
If you’re not using the ROKU WeatherFlow application, I invite you to try it!
The application works on ALL ROKU devices.
For those interested, I am proud to say my ROKU WeatherFlow application currently has 4,300 users!!
I am interested in the opinions of people using the ROKU WeatherFlow channel to view WeatherFlow data?!
All the questions below are related to “ROKU WeatherFlow Data Viewer v5”.
  • What do you like about the application?
  • What do you dislike about the application?
  • Is it easy or difficult to navigate through the menus?
  • Do you have more than one station saved in your menu?
  • Do you have “saved stations” in the app other than the units you own?
Thank you in advance for the feedback!!
—Steve—
Hey Steve,
Thank you for doing this.
Still using this (setting up once again after another Roku reset) September 2026.
Suggestion, if possible. A way to export settings like IP Camera Viewer Pro app. If necessary to reset Roku to defaults for troubleshooting, an easy way to import multiple weather stations (4) & alias modifications.
Thanks,
duo
