Wfpiconsole update Windows - Anaconda
running wfpiconsole update does not work at the prompt in Anaconda in Windows 10…
Nope it never will. The wfpiconsole command is Linux only. What steps did you follow to install the PiConsole on windows initially?
Thanks - I didn’t think so…
For Windows - only thing I attempted - in one form or another is running WFPICONSOLE Update inside of the Anaconda prompt.
Nothing else.
Otherwise, - minus the update prompt - flawless.
I have an additional Surface Pro running Pi Desktop - updates fine - (usually… :slight_smile:
-Craig
I think the best bet for you is to find and backup your wfpiconsole.ini file. Then delete your entire wfpiconsole folder before following step 6 on the advanced install instructions for windows
And this would be the standard way whenever there is an update? - for this particular install?
Yes, that’s correct. Once you have followed Step 6 in the instructions, you can copy your wfpiconsole.ini file back into the new wfpiconsole directory, and you should be good to go with the updated version
Easy enough!
Thanks!
