Wind reading way low since battery replacement
It depends on how the upgrade process is settled up.
You can do this safely. But depends on the hardware design.
Well, I am looking forward but I think it is an issue with data processing within the Skys head hence a Hubs update will scarcely have the ability to influence.
here a nice view on how the hub V98 cuts off when the hub V99 doesn’t. This is low wind conditions. (km/h)
22
Any updates on issue?
Chuck, David has posted in this topic.
https://community.tempest.earth/t/wind-speed-seems-to-be-reading-low-solved-in-firmware-v94/1510/120?u=garyfunk
Ah. My router has been down for 3 days so guessing I didn’t get update. Hope to have it back up soon.
The solving makes strange progress … as I see the situation, after the tests are finished, the new firmware will be rolled out to all stations. Probably not v101 :wink:
Correct. We’re up to v102 now, with fingers crossed that the 102nd time’s the charm!
