[App] Selectable Display on Temperature Section
I would suggest doing away with “Feels Like” and be able to select between “Dewpoint”, “Heat Index” and “Wind Chill”.
Too often I want to quickly see what the “Dewpoint” is but am shown “Feels Like”.
If others still want “Feels Like” that could be a choice as well.
I don’t see a feature request section, so this going here. Admins may move if they see fit. Please allow option to show dew point at all times instead of feels like. The fells like temperature, especially on the warm side is relative to the person, and we should be promoting use of dew point over RH and feels like as it is an objective measure, and not based on the temperature.
Thanks,
Mike
Make sure to click on the Vote button at the top of this topic.
I really value seeing the different values. Where I live the windchill in the weather has a significant impact on the (cold) temperature and it can be the difference between staying outside for an extended period of time and having frost bite in a few minutes.
In the summer the humidity can be high enough that going outside without water can lead to heat exhaustion pretty quickly.
So being able to see the different values and also have a default setting for what’s shown on the main card (or both!) would be huge.
Honestly, on the cards if I could just see “temp / feels” or “temp (feels)” I’d be good. Ie “-12 / -20” or “-12 (-20)”.
