Thanks for letting me know. It’s downloaded and working great!
v3.8.5 with FULL Tempest compatibility just pushed to GooglePlay… both btstWx and btstWxPRO.
Should be seeing update notifications in the next few hours.
iOS update coming soon.
Confirmed! New version is working great with my Tempest on a couple of Fire HD 8 tablets. Looking forward to getting this on my iPhone and iPad soon too. Thanks!
Do I still use SWSXXXXX for the Tempest? Mine seems stuck on Verifying access
GooglePlay
Thanks
Yes…
What version OS are you using… and what is your station ID?
I’m using a Kindle Fire with GooglePlay 20.1.17 installed.
The app seems to be working okay.
I’m using SWS18182 Station ID 18182 (Black Forest Ranchettes)
Ok. It works for me without issue… on BtstWx and BtstWxPRO on Android 10.
What is the Android version your Kindle Fire is running?
I can’t get it to display my own stations now. It always goes to one of the “demo” stations. I uninstalled and reinstalled it and it reverted back to the previous version so I uninstalled again and then went to the Play Store, searched for it and installed it again and am stuck with the demo stations again. I finally did an uninstall, reboot phone, and reinstall and keep getting the same results, only SWS1158 data no matter what I select.
I’m on a Samsung Galaxy S20+ with btstWx PRO 3.8.5. Here is a sequence of screens I get:
Very briefly this screen appears.
I get this on the first run.
Definitely not the station I selected. It is currently 62°F.
Click the Gear and select Switch Stations… then try your station.
Unless your station is set to Private…
I’ve done that multiple times and get the same result. All are set to public: 5075, 5080, and 12859.
What Android version are you running?
Android 10, the Samsung varient on the April security patch level.
Ok. Let me see what’s up on my end.
@gizmoev
Is it working for you now?
All 3 stations work for me without issue.
–Sam
iOS v3.8.5 is now available in the App Store.
Fire OS 5.3.7.0 Updated as of today.
Weatherflow Tempest works okay, if that helps.
Apple iOS works fine.
Ok,
Fire OS 5.3.7.0 is an Android 5.1 derivative. I have an older Android 5 tablet that I will double check it on.
I downloaded the latest iOS app version and found a couple of nits. I have an iPad Pro 11” version 2 running the latest iOS and I have the Tempest. On the first screen that comes up if I touch the screen the app dies. If I change the barometric pressure to mb/hPa then the pressure doesn’t fit within the box. It does in some of the themes. The lightning since midnight title also overflows the box. I have added two images to show the issues.
ETA: when I say touch the screen I mean someplace other than the icons at the bottom.
No change. Something is really strange on my phone. I’ll email you a video.
