When I took my “Mobile” SKY down before heading home I noticed some rust colored water. Upon closer inspection I saw that the gasket in the base was rolled over on two sides. I don’t remember seeing this before so I don’t know if I just missed seeing it when I opened up the kit for the first time or if it rolled over when mounting/dismounting the SKY. I was able to pull up the gasket with a rounded flat blade and seat it properly without taking the base apart. No water leaked into it since I fixed it. Here is what I found:
