Coming Soon: New & Improved Tempest App
Thanks for the info, I will take a look into it. The update interval for widgets should be every 15 minutes.
Hello, how do keep dark mode on so if i share a link to my weather station everyone will see it on dark mode? I noticed when i share link the background color does not stick.
Thank you so much. .
Hi @user152. Light and Dark mode is a user setting. So if you share your station with a friend, they might view the station in a different color scheme. For users viewing your station that don’t have an account, the color scheme will be whatever their system preferences are.
I noticed this mentioned before, but it just happened to me that the widget is not updating. It is currently 1300 and the widget says clear night (0 UV) and 51F when in reality it is SUNNY (8 UV) and 71F. Also as stated by someone else, opening the app from the widget does not update the widget.
Is there a way that I am missing to force an refresh?
Color is horrid. Hard on the eyes and just plain ugly. Please give option to change back.
When adding a location and choosing ā€œSelect location using mapā€ the forecast is not correct. It seems to use my station if I don’t choose another city first and even if I enter a different location and then move the marker on the map to the same location, but starting with different cities first I get different forecasts. Shouldn’t the forecast be the same if I move the marker to the same location on the map?
Which platform are you on?
I am using an iPhone on iOS 15.5.
I have found the issue with widgets not updating. I will have a fix for this in the next release.
Nice job. Looking forward to it.
I would like to see a Location feature, so as I travel, I can easily find the closest Tempest Unit for weather data and forecast.
There is a location that you can select that shows you a forecast based on your GPS coordinates. You need to enable location services on iOS/watchOS or Android in order for it to work.
An idea for the next release… I’m traveling and have only very intermittent internet. Instead of showing ā€œno network connectionā€ at the start of the app and do nothing, why not display the old data, with probably a still interesting forecast, perhaps with some banner on to show that there is no internet connection
A post was merged into an existing topic: [App] Favorite Station to a favorite list
It seems like the widgets stopped updating again. I’ll restart my phone just in case, but my station and a location widget just stopped updating yesterday.
My widget switch to Fahrenheit. I just removed it
Having the option of keeping the Blue would be an even better improvement. I’m not a fan of the new color.
Had to reboot my iPad2 and lost old tempest app. New app is not compatible with old OS. Also browser unable to access tempestwx/station/xxxxx
I get nothing on the screen.
Is there a way I can access tempest with my old ipad. (OS 9.3)
