DHCP issues with newer Tempest Hub
Curious if any others are recently experiencing DHCP issues with their Tempest Hub.
Please message me directly if you are.
No DHCP problems here with my hub. What sort of problem have you been seeing? What are you using for DHCP?
Make sure you have a 2.4 GHz wifi setting and DHCP scope on your network…
Am using pfSense running ISC DHCP Server.
And yes, of course 2.4 WiFi setting and scope.
It works, then if ever the WiFi is interrupted for some reason (power, etc.) I have to go and manually power cycle the hub to get it to obtain an IP address.
Otherwise, it just reconnects to the WiFi and sits there - not requesting DHCP.
All other devices on the same WiFi Access Point are NOT having any issues.
Has worked for years.
Issue just recently started.
Am wandering if recent Tempest firmware update introduced this new problem…
I am using pfSense with Kea here. What are you using for a wireless AP?
Samsung WEA-453 Enterprise Outdoor AP
I have never experienced any DHCP issues with two Tempest setups. Using all Ubiquiti Unifi network gear.
