How to get a full month graph for solar radiation?
I’ve seen graphs of data for a month or more posted online from the Tempest, but I cannot figure out how to get that from my own Tempest.
I can get info for one day ie, solar radiation, by clicking on that metric, and a graph shows up, but I have tried everything I can think of, both in my app and on the website, and nothing.
I am on Mac OS Sonoma, if that makes a difference.
maybe use the tools to zoom in and out ? :innocent:
O…M…D! Mine are tucked away in the bottom left corner, I NEVER saw them until you pointed out that they existed. :blush:
THANK YOU!
That means you installed the iOS app on your mac. What I show is the webpage version that you can access via https://tempestwx.com
use the same credentials as on the app.
OK, got there. I take it we can only get the current month’s data, not historical month-by-month?
Hi @zachsmail2925 ,
If you are viewing your graph in a browser window on your Mac use two fingers to slide the graph sideways to view history.
If you wish to get your history into a spreadsheet that is also possible. Use the search magnifying glass to find how to do that. By searching for ‘excel’ I found this…
Thanks! I have bookmarked that solution. We’re doing solar feasibility work, so having our own data will be very helpful in this process.
Hi @zachsmail2925
Be aware that your Tempest solar sensor does not face the sun. It is a horizontal flat surface. To measure the ‘actual’ solar energy the Tempest sensor should be perpendicular to the sun. That would only occur if the sun is directly overhead. It means trying to match solar panel generation to the solar W/m2 measured from the Tempest requires some trigonometry which changes every moment or by mounting your Tempest at the same angle as your solar panels.
Searching on ‘solar’ returns this thread where I mention the issue.
But, the error would be on the underestimating side, and not over-estimating side, correct? It would at least give us a rough idea at what we would be looking at.
We’re looking at passive solar air heating for an outbuilding, with some solar panels to feed lighting and small water recirculating pumps for hydroponics…
There is no significant error if you apply your correct calculations and adjust for the angles.
For your passive heating as an example I imagine you want morning sun in winter which begins from sunrise. At sunrise the low angle of the sun will stream almost horizontally into your building and produce good warming including onto your body if you are standing in the window. BUT at that time the sensor of the tempest facing vertically upwards is only receiving a small amount and is reading very low compared to actual warmth coming in your window.
Then in midday in the middle of summer when the sun is at its highest point it is directly facing the solar sensor which will read its maximum but depending on your building design if it is a tall building then the amount of passive heating is not proportional.
From my experience of electricity generation and battery charging rather than calculating the average amounts you should find the most difficult period where you wish to maintain sufficient charge and provide for that. Then the rest of the year will be fine.
So go to where you see your cloudiest overcast dark wet short days for several days in a row.
Find where your battery would have been fully charged prior to the shady event.
Now calculate your demand of the lights and pumps over the shady wet period and compare how much sun energy you received to calculate how many panels and size of your battery.
Thanks, this is a great explanation. :+1:
