IFTTT support for device battery voltage
Would like to see the addition of battery voltage for any/all devices at a station as an IFTTT trigger. For example . . . I would like to configure an IFTTT applet to trigger an action (such as an e-mail or SMS message) when SKY voltage drops below a user-specified threshhold so that a station owner can plan a battery replacement trip to the roof for a day that is convenient (and good weather, too). Also useful for AIR when installed in a remote sensing location.
This would be almost exactly the same function as the current WeatherFlow IFTTT service for temperature threshold where there is a scrollable list of stations and devices to pick from . . . except for battery voltage instead of temperature.
Until a solar panel option is available, this IFTTT function would be a big help for owners who may have several stations where they accumulate data but don’t necessarily look at the stations all day on the app or the Web.
I could add this to my software (I already have that available for other hardware)
I added two alerts. One for “Low Battery” and one for “Replace Battery” which go with “No Responce” for each device.
Q
what is a low battery reading
This is the code I use.
	if (Type == 'SK') {
		if (V > 2.4) {
			return 'Good';
		} else if (V > 2.1) {
			return 'Low';
		} else {
			return 'Replace';
	} else if (Type == 'AR') {
		if (V > 2.7) {
			return 'Good';
		} else if (V > 2.4) {
			return 'Low';
		} else {
			return 'Replace';
is that based on something official ?
(e.g using 2.1 as a threshold for the SKY)
Those low voltage numbers are as official as they will be until we get more data!
I made them up based on hours of testing. Two of the numbers came from WeatherFlow.
I did it this way to give RTI customers time to call their installer and give others time to go buy batteries.
Thanks to all who replied to this topic.
My thought when I opened it was that, in addition to the battery change alerts for the WeatherFlow devices, I could see various other uses where an owner might want to turn on (or off) certain heaters or coolers at different temperatures. Like a frost prevention heater at “getting close to freezing” and then a “big honkin’ heater” when the temperature goes considerably below freezing (eg: stage 1: keep the livestock water tank from freezing and stage 2: put more heat in the barn for the livestock). Hence, the idea that a user-configurable IFTTT might help do all of that.
Dan, that’s exactly what I do with RTI XP controller and the UDI ISY. The ISY controls Insteon and Z-Wave devices. The RTI is used to control all IP devices. Each of the two controllers does what it does best.
The RTI acts as a self-contained nodeserver to the ISY and both units interact with the other.
Very cool Gary! I certainly need to learn a bit more about those controllers as I have a consulting project coming up which involves a very large greenhouse operation (and a 500kW generator system, too). The project would typically call for PLCs but they are really overkill in both price and capability for this one. I am thinking of how to incorporate WeatherFlow devices which might save the client tens of thousands of bucks!
