ISY Polyglot Node Server
In addition to the standalone node server application, I’ve also created a Polyglot version and it’s available in the ISY Polyglot node server store now.
The version available through the Polyglot store is a simplified implementation. At this point, it only makes use of local UDP data and only creates the main Air and Sky device nodes on the ISY.
However, the installation and management of node servers is much easier using the Polyglot framework.
Thank you so much for your continued contributions in this important area of home automation. :+1:
