New Tempest Not Mapped Correctly
I just set up my Tempest this morning. On the map it shows up about 1/2 mile off from where it is mounted. How to correct??
Thanks
you have 2 locations in the settings
one under ‘station’ and this is used to calculate where you are and is NOT seen by the public if you set your stations shared. Under ‘public data’ is another place to set your location to whatever and is visible to everyone if shared. This is to preserve your privacy if you want.
The first is the most important one since it will be used by servers and Weatherflow service to get you the best data.
I guess the second is not where you would like it. Just set that where you want (depending on how private you want to stay)
