Not showing temperature, UV, Dew Point, Station pressure
My tempest had been working fine without any problems. Over the past week, it is only registering Lightning, Wind, Rain, and the Battery Voltage? There is no Air Density, Delta-T, Wet Bulb, Station pressure, UV, Dew Point, temp? Wondering if there are next steps? Thanks so much. Is this something if a problem under warranty?
What is your Station ID so we can look? You can also go to Settings, Stations, station name, Status to see if there are any sensors that have failed.
It says temp/rh/uv have failed ! Uh oh. ID is 96304
Thanks. Any ideas on what I need to do?
Try rebooting your Tempest. Sometimes this can bring failed sensors back online
