Online status on main screen and top of app
on main screen have a red/green :traffic_light: dot for the wifi, hub, tempest online/offline - very quick way to see status of devices on app and web browser - allow for a click in to get to the full status panel
That is already there, at least on the Android App at the very bottom of the ‘weather’ tab
This is what @glenngoddard is referring to.
Thanks. I do not see this on my iPhone.
Good spot would be right up beside the tempest icon in top right.
Or, fill the tempest icon with a color, corresponding to it’s status …
@corrineb this looks like a bug or oversight on the iOS app. It doesn’t appear on my iPad Mini 2, either.
Agreed. My hub was off-line for some time and I was not aware. There should be a very visible form of Network Connection Status: On-line Off-line on every screen of the software. This way every time you view the application you can immediately know if the hub has become disconnected from your network, prompting you to investigate what is going wrong. Also related to this is — When the hub is Off-line, the screen should also very visibly notify the viewer that the data you are viewing is NOT ACTIVE due to network disconnection.
It does change to red if offline.
