Sky installed for a few weeks on my roof. It is quite a bit lower than the surrounding trees, but the highest area at my house. The antenna is not currently in use. The tower itself is quite well secured, and is 1-1/4" EMT, with a small stack of adapters to go to 1-1/4" threads, then down to a 1" IPT nipple. Just a few minutes in the hardware store messing with piles of plumbing and electrical parts.
Air installation in the front yard. This is a south fence, so tucked up by it there is no direct sun on the Air.
Air securing method - short 1/4-20 socket cap screw and a fender washer. Easy peasy!
See the station here: https://smartweather.weatherflow.com/station/11922
And here (WeeWX): http://phidauex.com/weather/
I hope the antenna won’t create too much micro vibrations under high wind conditions.
I hope so too, if it does, I’ll remove it. There is also the possibility it is damping things a bit by adding mass and turbulence…
So far, the station has recorded max gusts of up to 21mph, with one moderately windy day, and it has recorded exactly 0" of rainfall (it has snowed, and one day of freezing drizzle, but no real rain), so I’m hopeful.
You could also fill the pipe with sand. Simple effective way to dampen vibration. Only thing to watch for is that the tube becomes heavy and it’s fixing needs some Attention.
I like the weather brick. If it’s wet, it rained.
LOL, maybe we could implement a computer vision system to let the brick serve as a calibration source for the Sky’s rain sensors. :wink:
That looks pertnear like my setup!
Ok, here’s mine. It’s at Cape Hatteras in Avon, North Carolina and yesterday it made it through the eye of Hurricane Dorian with eyewall winds in both directions, reported up to 98 mph in my neighborhood. I used gray PVC underground conduit to resist lightning and UV rays, and stuffed the 1" pipe in a 1.25" pipe to strengthen it and reduce vibration. It worked great.
Just a photo of SKY and the Ambient Weather Osprey watching the fabulous display of high Cirrus clouds that moved over the area today. We even had a brief appearance of a Sun Dog.
That’s a beautiful setup.
Thanks, Gary. They are both mounted to a wooden arbour on my back deck. Easy access for monthly maintenance.
Sky at the beach!
Having real-time hyper-local wind speed, UV, and air temperature (air not shown) at the beach is a wonderful thing :slight_smile:
WeatherFlow’s marketing team needs to spend less time in the office and more time at the beach, because the number of “What the heck is that?” questions I got followed by subsequent interest in the product was quite remarkable!
All I need is a small floating buoy probe that I can slap a fishing weight on to measure H2O temperature, and life is complete!
WeatherFlow @ the Beach
or one of these - https://www.seattletimes.com/seattle-news/environment/sneaky-underwater-robot-spent-18-days-off-coast-to-record-these-sea-creatures-and-noisy-humans/
Have mine mounted about 20’ will be updating the location and height later this spring. Will also be adding a remote tempests once it arrives.
Just got mine, right now I using the arlo camera mount for both. But the sky may still be too low for accurate wind!
The roof will really affect what wind it will see. Even at the peak would be better than where it is.
Yah I prob get an antenna pole or this ambient weather one: https://www.ambientweather.com/amwewe.html
Here is what I have.
Do U need to do a lightning ground?
No, the rod is vinyl covered wood.
