Here is my new installation, using a Weather Vane Mount and vinyl Wood closet pole that I cut in half
Oops, I also meant to say that it is a outdoor wooden Flag Pole not closet pole!!
BTW, there is a little pencil icon on your posts you can click to edit a post if you wish.
Oh wow! I should have seen that! Thanks!
Hello all –
I am looking for the right J mount that will allow me to mount my SKY on the side of my chimney. I will be looking to use metal wraps to affix the mount to the chimney. Please let me know if anyone has good mounts for this application. Thanks for looking. Colin
Are you looking for something like the mounts I used shown in this post above? Photos of Sky and Installation
Tell 'em it’s a fish finder device and watch their reaction! :wink:
@ [monty.ericson] - nifty idea with connecting another pole onto the RBI 4G pole - where did you source the brackets and pole from? Mitre 10? Bunnings?
Can’t wait to receive my Tempest (hopefully May) and install alongside my Davis 6163, and connect into Weather Display.
Cheers Paul (@deepsouthster)
Hi @deepsouthster,
In Australia Bunnings have this narrow pipe which I attached to some old scaffold pipe with some old temporary fence connectors I had lying around my spares.
I do like the brackets @monty.ericson used so I am also interested in his response.
Decided to mount on a rooftop using a 18 inch one inch pipe and i used a 90 degree bend and floor flange plus I small piece of pipe and it works well
I used 10’ of 2" PVC pipe on the outside to mount my Tempest. Then I used 1 1/2" pipe filled with sand. In addition, I 3D printed some rings so that the inner pipe fits tightly inside the outer pipe. I have my old Sky mounted on a 2" galvanized pipe. Even in strong winds I see no perceptible movement with either unit.
Curious where you purchased this and the brand if the mount? Thanks!
Hi. I got mine from Amazon. It was a Wilson Electronics 901117 Mount.
I’m going to order the Tempest product, and I like this installation method - relatively inexpensive, strong / solid anchoring. My biggest concern would be the effect of heat emitting from burning a fire in the fireplace during the winter months. Further, what would be the best method of grounding a galvanized mounting pole? Oops! I thought I was sending this question to person who showed his chimney mounting scheme picture and didn’t realise this would be for general consumption. Sorry, I’m still learning this messaging system.
In my case, if there is any wind at all, I don’t see any effect on the Tempest. I have just heat from my 60+ year old gas furnace. I do see that the temperature and relative humidity (and thus dew point) are effected on very calm days. I haven’t been able to notice a change in wind, however. I wouldn’t use too short of a pole. Mine are 8 feet long and extend about 6 feet above the top of the chimney.
Furnace vent is on the far left. Tempest is the one on the right with the SKY to its left.
Thank you, Gizmoev! Very helpful…
@ershler Please explain your 2" PVC pipe to mount your Tempest. I was understanding that Tempest needed a 1.25" to 1.31" OD PVC upon which to mount it. Thanks…
He describes an adapter setup to hold the smaller pipe.
The top of the 2” PVC has an cap with a hole in it. On the top end of the
inside pipe is an adapter to a smaller piece of PVC, that just fits in the mount on the Tempest.
However, the whole idea is not working as well as I had hoped. The whole rig is leaning somewhat. The fact that ultrasonic wind sensor is not sitting “flat” is causing the wind speed to be too low when compared with the old SKY. I am going to use some guy wires to straighten it up.
Phil
Since the batteries died in my sky and I had to put on the new cold air SPA I tried to stable it some more from vibration, see how this works
