Sager Fcst "ERROR: Missing METAR information. Forecast will be regenerated in 60 minutes."
I’ve been seeing this for the past 3 days. Anyone else with a ‘wfpiconsole’ noticing this? It could be an issue at “CheckWx`s” house . . . OR . . . it could be an issue with the nearest ASOS site from KOFF.
I checked and my CheckWx username, passwd, Email. . .and API Key are all still valid and the API Key is still currently listed in the wfpiconsole.ini file on the RPi4 device.
I have the settings on ‘wfpiconsole’ to generated a new Sager Fcst every 3 hours beginning at Midnight LDT (12:00 am) daily.
At 16Z today. . .I revoked my previous CheckWx API Key. . . and REgenerated a new one then updated it in “wfpiconsole.INI” file. This did not help. Still getting the ERROR message on ‘wfpiconsole’ when touching the Sager button. I even sent a message to CheckWX Support. . .but have not heard back from them.
I just checked, I’m getting the same error. I don’t use Sager, so I hadn’t noticed it.
I think I MAY have found the problem on my end. That is. . .the Offutt AFB Tower Information “Echo” on 273.50 MHz (UHF) is broadcasting the latest METAR obs for KOFF. . .but. . .the “skyvector” chart for the Omaha area. . . shows that NO METAR observation is listed for KOFF.
@lauraf13 since you are getting the same result. . .there may be an issue with the sager.py file in the “wfpiconsole” directory? I hadn’t messed with any of those files what-so-ever (for fear of dong something I’d regret).
Wait – Lo and Behold. . .my Sager Forecast just updated updated at 12:00pm CDT! . . .after being non-existent for the past 5 days
“Fair: Wind moderate to fresh (13-24 mph). South or southwest.”
@lauraf13. . .try yours again to see if you are getting the Sager Fcst. What is the ICAO (Airport location) nearest your weather station. . .so I can check skyvector to see if there is an updated METAR obs.
Mines working now. KDFW or KDAL are the closest airports.
Will chock this up to a temporary (UNwelcomed) glitch in some sort of API -circle! Hope all of our stations stay up and the data continues to flow as it has been. . .uninterrupted.
This sounds like a glitch with the CheckWX API. Good to hear it is back up and running
So last week. . I sent a message to support @ CheckWX asking if they knew of any problems. This is the response I received. . .
Subject: Re: CheckWX API Contact Message
Thank you for contacting me.
There was an outage that effected all operations on checkwx.com. This issue has been resolved.
I apologize for the inconvenience. Further details can be found at https://checkwxapi.com/status
Regards,
CheckWX
Shortly after that. . .the “ERROR” problem for the Sager Fcst was alleviated. . .and the Sager Fcst once again appeared at the touch of a button. . .like nothing ever happened! But. . .starting back on the 4th (two days ago). . .the “ERROR” is back when touching the “Sager” button in the lower left corner of ‘wfpiconsole’.
Clicking on their status link (above) indicates. . .
…but. . . the “ERROR” still continues for the Sager Fcst.
just looked on mine, identical message to …
or an API overload or something else going way square… :face_with_spiral_eyes:
Thanks for the confirmaton @eric. Guess we’ll all have to wait till this gets “ironed out.”
Not much I can do here I’m afraid. This error is almost certainly an API fault. Interestingly I can’t access the checkwx domain at all at the moment….
Thanks for your confirmation / verification @peter. The problem is squarely at “CheckWX’s House!”
It would appear to me that the CheckWX API will never be fixed. . . so I eliminated the Sager button from my ‘wfpiiconsole’ :
Menu | Settings | Secondary Panels | Panel One | None.
Now…across the bottom…the only two visible buttons are “Moon” and “Lightning”.
I have only had my display for a couple of weeks, but this is the message I have seen right from the beginning. Was it configured wrong when I bought it? How do I fix it without making things worse?
Can you share your wfpiconsole.ini file with me in a private message and I’ll take a look into it. You’ll need to change the extension to .txt
How do I get it off the Pi?
Sent from my iPad
Did you install the console yourself or buy it as a complete unit from someone else?
Bought it from Donald Barnett. Supposedly configured for my location. He has not answered my request for help.
Sent from my iPad
