The skill for Alexa has changed. It used to be that when you asked for the temperature, it told you the temperature. Crazy, right? Now it tells you the temperature and the day’s forecast. Every time. How many times do I need to hear to expect clear skies with a high of x degrees and a low of y degrees? If I want it, I’ll ask for it! PLEASE change it back! You’re just as bad as Acurite, now!
