Has anyone else experienced this on their Sky sensor that runs off of solar? Once every day or every other day, I’ll get this random drop in voltage (see image). It doesn’t last more than 5-10 minutes, and the sensor continues to report no problem, then the voltage jumps back up to where it was previously. Not sure if this is normal but wanted to check, thanks!
This happens and as long it happens randomly with no other issues …
Short explanation : batterie level reading is a low priority process and if for some reason there is no time it just skips one or more readings (usually once and remember the interval is 5 minutes).
Don’t worry to much
