Tempest not showing current data
I’ve been having a problem over the last couple of months where the data on the live page freezes on data from 2 weeks or more ago. I reset the base station (receiver) and the live page will pop up and show 5 minutes old data then immediately pop back to 2 weeks ago.
iOS app shows version 5.40 (810), I don’t know if that’s the app version or the Tempest firmware version. I also don’t see any way to check for new firmware. Right now as I said it says the data is 2 weeks old.
Web (tempestwx.com) shows data is 16 days old.
I’ve been dealing with this again for several weeks after several months of it being fine. I don’t know what else to do to try to resolve this issue. Any help is appreciated.
EDIT: I just noticed the main weather page shows the device is offline, but I’m not sure how to troubleshoot why. I’m digging into this now.
Problem solved, and I left this up for others just in case. I connected to the base via bluetooth and reset the wifi connection and it’s fine now. I have no idea why this happened, and I’ll keep an eye on it and post again if it fails, but if not consider this as the solution if others see the same thing.
