Tempest True North Orientation
So I just set up my Tempest today. And I believe I have the orientation correct, but I want to make sure that this is correct. Is my diagram correct? My apologies for the crude drawing. Yes, I am in the northern hemisphere. Thank you in advance! Cheers.
Yes, that is correct. The solar panels are on the southerly side of the Tempest with the blue arrow facing true North.
Thank you @gizmoev. I thought so but wanted to double check to make sure. I would have felt bad if I had it incorrect because I have about 12 hours of data now. Good to know I have it set up correctly. Thank you very much! Have a great day. Cheers
