Troubleshooting Help
Hi All,
My station quit reporting 10 hours ago. I have reset the hub (app says is online) and I have switched the station off and back on by the switch in the bottom of it. Battery last reported as good at 2.11v. Anything else I can look for or do to troubleshoot?
Just noticed there is no status led activity at all when switching station off then on. Battery failure I guess..
Likely. You might try looking up your station online to see the battery charge dropping and look for any sensor failures etc., but plugging it into A/C power and charging it up might be wise unfortunately.
