Using ambient meteobridge with tempest? Is this possible
Hello, i have had for a few years an ambient weather bridge which i used with another weather station. Was wondering if its possible to use the bridge with Tempest? To upload to CWOP etc…
This is the one i have.
Yes, you can use it with Tempest. I had one running for quite a while until it randomly started freezing up on me. Basically it treats the Tempest as a SKY & AIR unit only with device numbers starting in the 100s rather than starting at 1. In the config file you will see two devices for the Tempest. I’m sure I have a copy of my config file if you want to see what the entries look like.
