Weather34 WF API version Discontinued
Good morning
finally at a level where confident of releasing two versions one uses the official Weatherflow API and the other uses the meteobridge UDP method.
both work very differently yet the display and visual side is almost identical.the API version is restricted to 1 minute update intervals as set by weatherflow themselves from there servers.
the meteobridge version is fully adjustable to suit what your server can handle in terms of update intervals in seconds. using the meteobridge does not affect in any way of sending data to the weatherflow servers it simply acts as a hub and sends the data to your hosted server.
you can also run the template locally on your desktop pc etc however you would need to simply install a remote file on your server to generate a simple text output if you do not want to run the template on a public hosted server. (you can email me for more information on this process).note this method is for running only on your local desktop enviroment.
screenshot below gives an idea of all that is required to use your weatherflow AIR+SKY combination.
both versions available via https://weather34.com/homeweatherstation/
weatherflowmar
The ā€œDevelopersā€ category is more for developers helping each other and sharing information. ā€œThird Party Integrationsā€ is us to post working products. Here, you have a home to post information about your application and where others can ask you questions.
Gary
ok perhaps i should spend more time on here i wasn’t aware it was shifted around or didnt notice… anyway thanks
meteobridge and newer weatherflow API version updated this morning 17th March couple of new modules and thanks to @Phoenix for the idea of battery inclusion . newer uv-solar now includes lux as always available via https://weather34.com/homeweatherstation/
…brian
17marwf
Hello Brian
just installed your theme to see how it works. I know, most isn’t working as I don’t have the Sky ā€˜yet’ but still, good to learn already.
One thing I noticed already (not sure if you can call it a bug), when you ask a detailed chart when you have the light theme, the popup is again the dark theme. Is this to have a better contrast ?
00
all charts display in dark background… however if you wish to have lightbackground charts and dark fonts feel free to edit and i should say good luck incredibly tedious adding switching based on theme selection probably more trouble than its worth hence never bothered and has always been that way for last couple of years… brian…
was just curious and won’t go fiddle with the code, most probably I’d break it :slight_smile:
following is maybe a bug ?? We just had a few lightning impacts nearby and I think the module doesn’t follow time zone
here we are on the same timezone all year round no dst or utc changes … if you send your station id i can check here from the desktop
station id for me is 2230 (France), next week end we switch to summer time, so we go 1 h forward
came up as 14:32 last detected using 2230 and your air device id …
2230
wird, it still shows 13:32 for me
this is how I set time zone in the settings, nothing else to configure …?
54
ok i’ll replicate them and see if it does the same
ok i cant replicate that issue inputted same timezone etc … is it a local server or hosted ??
er
hosted on a server I manage, it is also set at europe/paris but physically in Canada (whm/cpanel
ok lets try this im sure you can do this easily
top of the file wflightning.php
replace
<?php include('settings.php');include('shared.php');;header('Content-type: text/html; charset=utf-8');error_reporting(0);?>
with
<?php include('settings.php');include('shared.php');date_default_timezone_set($TZ);header('Content-type: text/html; charset=utf-8');error_reporting(0);?>
easy enough :wink:
just had another close strike detected, this time the time stamp is correct.
good stuff so ill leave that in there i think…thanks for the feedback…brian
For the API version I am guessing we edit the settings.php and don’t use the easyweathersetup.php? I am checking because the easyweathersetup.php looks like is for the meteobridge setup. If I am correct can someone post a sample of a working settings.php file. That will help me figure this out I hope. If not please point me in the right direction. Thanks!
I have it all loaded to my web page which supports php. What file do I call to actually see the data? I know I am probably missing something beyond this file…
if you downloaded correct version which should be the api version just use easyweathersetup no need to edit files direct.
index.php is always the main file
please remove the api key from your post thank you.
Thanks…removed API Key. I had both a new and old version of the easyweathersetup.php. Removing the old got everything working. Waiting for SKY…but this looks great!:
