WeatherFlow Data on ROKU
I am sorry you are having problems.
Can you delete all stations and try station 86411 ?
Does that work, when it’s the only station?
Can you send me your station number ?
Hi, The “Everglades City” works fine. As soon as I switch to my station “65045” Welshtown NS it unloads just after it quickly displays. I have deleted the app and reinstalled it many times with the same result.
??? Hal
YEP . . . you found a bug :slight_smile:
I will fix the code and schedule another release.
In the meantime, if you take the comma “,” out of your station name it will work.
Thank you !!
Steve
Thanks Steve, I was beginning to think it was only on my end. Things happen…
@TwoDogs
The code is fixed and staged-up for release.
Because of the Thanksgiving holiday ROKU has a change-freeze.
The new release will happen on 11/27/2023 at 10am PST.
Of course, like I said; If you remove the comma from your station name it will not encounter the error.
Thank you again for troubleshooting.
Awesome, thank you so much!
Steve,
Any plans on the ability to show pressure in inhg?
Thanks,
tweatherman
no
meeting the 20 character minimum :slight_smile:
