Lately I have noticed that the wind and temperature icon on the WU map is showing odd behaviour. The temperature seems to be showing two values superimposed on each other, and there are multiple - 5 to 6 - black wind direction lines that appear at once. Is anyone aware of what might cause this behaviour?
Tom
I have the exact same problem too.
If you scroll way in it may be caused by someone else has another weather station within close proximity to yours I have 2 stations reporting from basically the same location and I get that and have to zoom in to fix see both stations
I appreciate the suggestion but unfortunately that is not the solution in my case. I have asked the question at WU but have not yet heard back from anyone.
I tried zooming the map under both Safari and Firefox. Neither worked.
