Add an Air unit for indoor temperature to a running Pi Console
Is there a HowTo somewhere that shows how to add an Air to a running Pi Console?
One way would be to ‘save’ your wfpiconsole.ini file for safekeeping to a different name and do a start and it will prompt you for everything since it’ll be setting up a clean .ini file. You’d need to cut+paste the station and key(s) in to once again answer those questions.
Another way would be to edit the wfpiconsole.ini file and add the InAirID near the top of the file in the [Station] block.
I don’t have one handy to know where/if there is a way in the gui to do so. My piconsole is all boxed up currently.
